#1: Great idea. Agreed. I presently own three different models of of filament dryer, and one of them is the Print Dry Version 3 filament dryer, which, for what it is, is a stupidly expensive piece of kit (around $199). At the time I purchased it, I was in a rush and so I relied on what seemed like near consensus among the reviewers that it worked decently well. Moving along: I put two different wireless TH sensors inside PrintDry while drying some PLA to monitor the conditions inside. Both were made by Yolink, but they were different models and both were spec’d to have an operating temperature range up to 70C (by their own measurements they were comfortably under that limit). Naturally, they did report a lower RH than the ambient RH in the room housing the Print Dry, as you would expect because of the much higher temperature inside the Print Dry while drying the PLA. As a convenience, both sensors also report Dew Point (which if they hadn’t reported, you could easily calculate using either formulas or an on-line calculator, given the measured temperature and RH).
Worthy of note: there are a lot of holes in the PrintDry “shell” which serve as “ports” for filament inside the Print Dry to connect to a 3D Printer located somewhere nearby. For this reason, I was initially worried that the dew point inside the PrintDry might rise enough to, in the limit case, go as high as the Dew Point in room housing the Print Dry filament dryer. Instead of that, however, both sensors reported that the dewpoint inside the PrintDry was actually higher than even the ambient dewpoint in the room housing the Print Dry. And this was after even many many hours of continuous drying inside the Print Dry. WTF? If the PrintDry had been airtight, this would, of course, make sense. But for a filament dryer that leaks like a sieve, as seems true for the Print Dry, I was surprised by this result. I have a couple different theories as to why this might have happened, but regardless of why it happened, it would maybe support your idea of pumping already dry air into the Print Dry during the drying process so that it could dry faster and more efficiently. Indeed, IIRC, BBL recommends doing that too, except upping the ante even further and doing it in combination with using a blast oven (well, at least for certain kinds of filament).
So, #2, not only is it a good idea, but for at least some situations, it may be highly advisable, and maybe even a necessity for some kinds of filaments.
Finally, with that background now covered, we can cut to the chase: #3, how best to do it? Well, lots of ways, but how to do it easily and economically? That’s the real question. I’m sure using enough tanks of nitrogen, or scuba tanks as some suggested, would get the job done, but surely there must be an easier and more cost-effective way than that?
