how do I print in 5 colors???
Bambu would like you to purchase a second AMS and hub
If clever, you can try to arrange your model so that Color#1 is only present in the lower part of the model, and #5 is only present in the upper part of the model. You can then re-use that AMS slot for both, by using your hands and literally swapping the roll midway in the print after #1 is finished up.
I have written about this many times.
You can achieve it easily as long as you have a maximum of four colours in any one layer.
OK thanks for the information I will probably use this a lot
