How do I pair?
I got my Cyberbrick kit yesterday and I hurried to make my first models. I’ve got the truck and the remote assembled, but I can’t figure out how to make them do anything. I can’t find instructions online anywhere for how to pair the transmitter and receiver (I used the iOS app to connect my phone to both units, but they don’t seem to communicate with one another.)
Can you point me in the right direction? Right now I am really frustrated and disappointed with this system.
Same here, got them both ready to go in the android app, all configs uploaded, but cant figure how to pair them together.
In the Makerworld Project for that kit, there are links to a number of docs, including assembly and getting started. (That may be in the github repository, I don’t remember or have access right now)
@cbandes / @user_1109046964 See below
I believe the @CyberBrick team will be creating a video guide this week. In the meantime, you can follow the screenshots I shared below. Note that this is from an Android app user standpoint as I don’t have access to an iPhone to get screenshots from.
Pro tip: Turn on one CB core first and connect it to the app before turning the other core on, to avoid confusion.
If you followed the steps above correctly, the receiver should now respond to the transmitter actions.
Thank you! I got it working :slight_smile:
I have mine mostly working, lights and steering work, but the motor runs continuously and doesn’t change based on the joystick. How can I troubleshoot? I connected a serial monitor to the controller, but I don’t see any useful information.
Which model did you make? Forklift, truck, SoccerBot?
In my experience, it’s usually due to the wire connectors not being pushed in completely.
As @chiz_m points out, it may be poor connections, however, in this case it may be poor connection in the remote, not the truck/forklift. Probably the throttle joystick connector.
I built the truck. It did end up being a bad connector wire between the joystick and the controller board in the remote. I replaced the cable and it’s all working proper now, fun stuff. I still didn’t find a good way to troubleshoot though, another day perhaps. Thanks for the replies.
Hello, yesterday everything worked fine but I can’t connect anymore. The board has a green led. Both my android phone and windows computer are recognizing the bluetooth device. When I try to connect it turn blue and after a few second back green. The android apps tells connection failed please contact support.
I used a tool to watch the logs:
[11:28:42]0-INFO- [MAIN]HARD_RESET
[11:28:42]0-INFO- [MAIN]SLAVE INIT.
[11:28:42]2-ERROR- [MAIN]CRTL TASK: can’t convert ‘int’ object to str implicitly
[11:28:42]ESP-ROM:esp32c3-eco7-20230720
[11:28:42]Build:Jul 20 2023
[11:28:42]rst:0xc (RTC_SW_CPU_RST),boot:0xc (SPI_FAST_FLASH_BOOT)
[11:28:42]Saved PC:0x403807f0
[11:28:42]SPIWP:0xee
[11:28:42]mode:DIO, clock div:1
[11:28:42]Valid secure boot key blocks: 0
[11:28:42]secure boot verification succeeded
[11:28:42]load:0x3fcd5988,len:0x1f38
[11:28:42]load:0x403cc710,len:0x6e0
[11:28:42]load:0x403ce710,len:0x5028
[11:28:42]entry 0x403cc710
It’s seems that my config has an integer where it expected a string.
Hi guys i tried to create a new standalone post but idk why it doesn’t let me publish it. I’ll post it here sorry in advance:
I received the CyberBrick base kit yestarday and started building the remote controller, followed all the intructions perfectly. As soon as i tried to turn it on the white led on the receiver shield turns on and the fades off not powering the remote. I tried all the core to exclude some problem witht the board itself, same thing with the shield, tried both but nothing. The Cores and the Shields work perfectly beacouse i tried powering them via usb c and they work perctly. What should i do?
Hello - which power source are you using? Is it possible that it has a low charge level?
I’m using the 3 AAA battery pack, new 1.5V alkaline batteries
I’m not sure I will be able to be much help but could you try it with the rechargeable battery to see if you get a different result? I guess I was just thinking this could troubleshoot if there is an issue with the a battery pack.
Had same problem went to laptop connected fine
Yeah I know but I want to use them with batteries, they are cool for that…
Any other idea how to solve?
I am having the same issue. The left joystick seems dead in both of the controllers. When using the right controller, i can steer left and right, but the left doesn’t do anything at all. I could understand if it was one of the controllers, but both?
Just to clarify, I cannot get my tracks to stop running. I am at a loss right now and I can’t seem to find anything that would help.
Sounds like you have the wrong control software loaded. One version (Forklift_B_L-throttle_R-steer.json.json) uses two different joysticks and one uses only one (Forklift_A_L-joystick-only.json) with steering and speed on two different axis. I would expect your behavior if using the wrong one.
See the bottom of the Makerworld page
To download the JSON files.
