Hello, I have a problem with my print. There is a name written at the bottom of the piece, and I would like to remove this name because it is interfering with the adhesion when I place it on the wall. Does anyone know how to fill in or remove the writing at the bottom of the piece?
Also, if there is a lot of room in the base…you can just drop it down through the bed 1-2mm.
You might want to use some sandpaper to gently sand down the name until it’s smooth. If that doesn’t work, you could use a bit of filler to cover it up and then sand it smooth. If you have access to a 3D modeling software, you can edit the model and remove the name before reprinting it. Hope this helps!
