How do I run frequency sweep gcode that Bambu support sent me?
Support sent me a frequency sweep test gcode file that they asked me to run on my X1C. Do I just replace the start g-code section a filament? If I just open Bambu Studio with the gcode file, it gives me and error saying there’s no valid gcode in the .gcode file.
Personally I would copy it to a sdcard and print it from the front panel.
You are telling us that Bambu support did send you a g-code package but without clear instructions on how and where to use it? If true, that’s the dubest thing i hear Bambu customer support has done in all the time I’ve been here. But then again, why wonder? The staff at customer support has done (or said) pretty stupid things before, but this bit of stupidity is brand new and … quite “innovative”.
Good luck. You’re gonna need it.
I tried that and when I select the sd card, it shows no files at all. I put a 64GB card in with only that gcode file.
=====diff x pos sweep test ==============
=====20220923_10:57==================
G90
M83
M104 S0
G28 P0
G1 X128 Y128 F6000
G1 X20
M400 P100
M970 Q0 A15 B15 C70 H20 K0
M970 Q0 A7 B15 C70 H20 K0
G1 X40
M400 P100
G1 X60
M400 P100
G1 X80
M400 P100
G1 X100
M400 P100
G1 X120
M400 P100
G1 X140
M400 P100
G1 X160
M400 P100
G1 X180
M400 P100
G1 X200
M400 P100
G1 X220
M400 P100
G1 X65 F6000
G1 Y264
G1 Z120 F600
M400 S1
If it’s as simple as just opening up the file, then instructions probably weren’t necessary. It’s pretty clear at this point the file they sent is invalid.
It needs to be formatted FAT32, 64GB might be too large to be formatted that way from the factory. If you didn’t, I’d just take the existing one out of the printer and put the file in the top directory.
Both were formattated FAT32 64GB. Same exact sd cards in fact. The only difference is the one in the printer worked when I put the file on that while the other one didn’t for whatever reason.
How did you end up running the g code they sent you? They sent me the exact same g code with no instructions on how to run it.
