How do we switch from AMS to the Spool Loader?
What’s the official procedure to switch from AMS to the spool loader?
I tried it with the small mounted LCD display where I unloaded filament, and then tried to load from the spool loader. But I can only get it to work by unplugging the AMS system. If I don’t, the print will try to do stuff with the AMS system…
Is there something I’m missing or is this the proper way?
When printing from LCD - you need to untick the “Use AMS” box from the printer LCD
or - if using slicer software to print
Make sure your slicing correctly and definting the spool holder print and when you “send to printer” make sure again your unticking “Use AMS” in the studio software.
Well that sounds obvious !!!
Thanks DruiD !!
Yeah I still forget when I want to FORCE it to use a rear spool, with my splitter systme and AMS still connected, it starts to use rear spool. then AMS takes over - retracts, and tries to use the AMS… I then realise i forgot to untick Use AMS - doh.
