Hi everyone,
I have a question about how to describe compatibility with a branded product when MakerWorld does not allow you to mention that brand name or its model designations.
Let me explain what happened.
About a year and a half ago, I uploaded a 3D-printable magazine loading tool for airsoft enthusiasts. It’s a simple accessory that makes loading BBs into certain airsoft magazines much easier and helps prevent the BBs from being inserted incorrectly.
The tool was designed for airsoft magazines that follow the Glock-compatible magazine standard, including those used by airsoft replicas from manufacturers such as Tokyo Marui, VFC, and Action Army (AAP-01).
The model was quite successful. Over approximately 18 months, it received thousands of downloads, hundreds of likes and boosts, and became one of my more popular designs on MakerWorld.
I never used the Glock logo or any other Glock branding on the actual printed model. I also never claimed that the product was manufactured, endorsed, or officially supported by Glock.
The brand name was only used to explain compatibility. For example, the images included the text “Compatible with Glock Airsoft Magazines,” and the description listed the airsoft manufacturers and replicas that could use the loading tool.
Then, after approximately 18 months, the model was removed from MakerWorld.
I never received an email or notification informing me about the removal. I only discovered it when I wanted to share the model with a friend and could no longer find it.
When I contacted MakerWorld, I was initially told that the appeal period was limited to 20 days. Unfortunately, since I hadn’t been aware of the removal, I hadn’t had the opportunity to respond within that period.
After asking for clarification, I was informed that the removal was related to the use of the Glock brand name in the model’s title and description.
I explained that the brand name had only been used to identify compatibility, not to suggest any official connection with the manufacturer.
I also mentioned that searching for “Glock” on MakerWorld returned more than 1,000 results, which made the situation confusing to me. I genuinely didn’t understand why my model had been removed while so many other models using the same brand name were still available.
MakerWorld subsequently explained that the removal had been made following a takedown request from Glock.
To be clear, I’m not asking MakerWorld to ignore such requests, and I understand that the platform has to deal with trademark complaints.
However, I do find it frustrating that my model could disappear without any notification reaching me, leaving me unable to appeal within the stated deadline.
A MakerWorld representative was eventually kind enough to explain that I am allowed to upload the model again, provided that I do not use the word “Glock” anywhere in the listing.
I appreciate that clarification, but this leaves me with a rather frustrating situation.
I’m allowed to upload my model again, but I’m not allowed to use the very information that tells people what the model is compatible with.
And that’s where I’m struggling to understand the logic.
Why not simply list the compatible airsoft manufacturers and models?
You might think I could simply list the airsoft manufacturers and their compatible models instead.
Unfortunately, that doesn’t really solve the problem.
For example, Tokyo Marui uses names such as Glock 17, Glock 19, and Glock 22 for its airsoft replicas. VFC uses names such as Glock G17 and Glock G19.
And according to the restrictions MakerWorld has explained to me, I’m not allowed to use either the Glock name or model designations such as G17, G19, and similar identifiers.
I could mention Tokyo Marui or VFC, but without identifying the specific models, that information is practically useless. Both manufacturers produce many different airsoft replicas, and my accessory is certainly not compatible with all of them.
Action Army’s AAP-01 is an exception because it has its own model designation, but that only covers a small part of the compatibility range.
So even describing compatibility through the airsoft manufacturers themselves doesn’t provide a workable solution.
I’m not looking for ways to break the rules
I want to make something clear.
I’m not asking for tricks to bypass MakerWorld’s restrictions by deliberately misspelling brand names, using coded references, or hiding prohibited terms in images.
I’m genuinely trying to find a practical and legitimate way to comply with the rules while still making my design available to the people who could benefit from it.
But that brings me to the fundamental problem.
If someone designs a replacement part, an adapter, a protective case, or an accessory specifically for a particular product, how are they supposed to make that part discoverable without identifying what it fits?
How can potential users know whether an accessory is compatible with their equipment if the manufacturer and model information that establishes compatibility cannot be used?
And perhaps most importantly:
If I am allowed to publish the model, but the people who need it have no realistic way of finding it, what is the practical value of being allowed to publish it at all?
My question to the MakerWorld community
I’m genuinely interested in hearing how other makers handle situations like this.
Have you encountered similar restrictions when publishing accessories designed for specific brands or products?
Have you found a practical way to communicate compatibility clearly without violating MakerWorld’s rules?
And perhaps someone from MakerWorld could explain how creators are expected to handle this situation, especially when the usual manufacturer and model designations are also restricted.
I enjoy designing useful things and sharing them with the community. That’s exactly why I published this model in the first place.
I would really like to be able to share it again, but in a way that makes sense for both MakerWorld and the people who might want to print it.
Thanks for taking the time to read this. I appreciate any constructive suggestions or insights!
