How long is too long to allow a print to be paused?
Just curious here. I had a print stop due to AMS feeding issues. I finally got it fixed and re-started the print. But, it was stopped for 8 1/2 hours. I’m letting it finish because it was 46% in to a 50 hour print, but I’m curious if there is an extremely high likelihood of layer adhesion issues where it was stopped for so long.
Well, there is an increased likelyhood. I did have such failures but none recently.
Instead, I did recently have good prints that had night long pauses. An 8 hour pause just over the weekend, so
The plastic shrinks as it cools. You don’t generally notice (provided you don’t get warping) because a new layer is printed before the layer below as cooled off a huge amount. But if you have a long pause and especially if the build chamber temperature drops, shrinkage will likely result in a visible “discontinuity”, a small offset in the walls printed after resuming, relative to the walls below. The previously printed part will be slightly smaller. For a thin wall, the shrinkage could result in the print failing.
And yeah, a hot layer laid down on one that’s cooled off won’t be as strong as a hot layer laid down on one that is still hot.
A low-warping material like PLA or PETG adulterated with whatever will shrink less. Matte filament – along with glow in the dark, wood and carbon fibre – tend to shrink the least due to the large amount of not-plastic in the mix.
ABS is pretty much ruined if it stops for more than a couple minutes due to its tendency to warp.
Thanks for the responses. Here’s to hoping it turns out ok. I was so far in that I wanted to give it a shot. Should be finished in about 10 hours from now. Later yesterday I ended up having my prime tower come loose from the build plate and move with the nozzle. I glued it back to the build plate and was pleasantly surprised that ended up working out. LOL
It really depends on the environment, as someone already mentioned. If the chamber temperature varies drastically, it may not last long before you start noticing a pause in print quality. I’ve had PLA Basic paused for over 48 hours before I was able to remove the issue and let it finish. The print turned out flawless, but this might not have worked with ASA, PAHT-CF, or other high-temperature filaments.
