How often A1 tip
How often do people change the tips? Or how do you clean it when it seems to not print as good
With regular use they aren’t typically a wear item unless its stainless, but as you’re having print defects you may need to clean it and do some routine maintenance regardless. A1 Maintenance Guidelines | Bambu Lab Wiki is a good read. The heater unit has been known to loosen up as well.
Yeah, the most common issues in my experience are the occasionally clogs, and once in a blue moon, loosen heater units.
Processing: image.jpg…
What is causing this build up?
I can’t get the picture to download on here
Just drag and drop the picture into the window?
Says the image is to large
It will print fine then all of a sudden do this. I did one print came home and it looked like when a tire would explodes. I had filament everywhere.
General suggestions:
  1. Check if the silicone sock is in good condition, I’ve found as the sock degrade, filament will sometimes stick to it during prints.
  2. If you’ve a spare hotend, swap it out to rule out potential hotend related issue.
  3. Swap to another filament to rule out filament.
