How to access camera on LAN ?(firmware 01.06+)
I cannot find the instructions for accessing the camera (in a browser or video app) when in LAN only mode. I’m trying to add the printer to VLC on macOS (as an example). I can see that in the MQTT messages there is this information:
    "ipcam": {
      "ipcam_dev": "1",
      "ipcam_record": "enable",
      "mode_bits": 2,
      "resolution": "1080p",
      "rtsp_url": "rtsps://192.168.234.100/streaming/live/1",
      "timelapse": "disable",
      "tutk_server": "enable"
However, that RTSP URL does not work, and the printer is not at that IP address. I can see port 322 (RTSPS) is open on the printer’s IP address, but I do not see how to connect to it.
How is the camera supposed to be accessible in this mode?
There may be some ideas here for a Mac, this has worked with VLC (Windows) in the past:
I did it once, just to see if it could be done, before going back to the using the Bambu cloud a few months ago.
I’ve not tried this method with the newer firmware. LAN-only video within Studio does work.
Try a URL of the following form (here shown using ffmpeg):
ffplay -hide_banner  rtsps://bblp:<security code>@<ip_address>/streaming/live/1
For me this is not reliable: it often takes many minutes to start-up. I did some tcpdumps and it hangs in the TLS handshake.
How does video in lan-only mode work within studio? I don’t get it.
Using Studio (or OrcaSLicer), the LAN-only video works just the same as it does through the cloud. Still no LAN-only video monitoring with the Handy app, but I think we will get that eventually.
Interestingly, it is the IP address that the printer has on the network connection via the Micro USB port on the AP board (once you’ve installed the appropriate Rockchip drivers).
I have a Camera Icon, but in Orca Slicer I get a Black screen with no error messages. Haven’t gotten the Handy App running yet as I work from my PC mostly.
Any help in diagnosing where to look would be appreciated
If you need a way to stream P1S video feed, see github[.]com[/]slynn1324[/]BambuP1Streamer
