How to clear the build plate in Bambu Studio?
I have lots of experience with Cura, but I’m very new to Bambu Studio. In Cura, there is a simple option for “Clear Build Plate” that - as the name implies - deletes all objects from the build plate so you can start a new project. If there is anything similar in Bambu Studio, I’m not finding it.
Where is it hidden?
Thanks in advance!
mouse click right button ----> delete all
Just normally go to create New Project and either save what I’m done with currently or dismiss the changes from that screen and get a new plate from there
JayZay:
Thanks very much for the answer. I was looking for that function as a menu item or something and didn’t think about right-click. To elaborate a little further, right click on the plate shows DELETE as an option if there is only one object on the plate and DELETE and DELETE ALL if there are multiple objects.
Thanks again!
Ken
No one has still answered the queston is there is a command to delete the entire plate contents without exiting the program.
The question has been answered.
Right click on the plate and choose delete (for one object) or delete all to clear the plate.
To clarify, choose any spot not occupied by a model and right click.
You can also choose the drop down beside file, choose edit, choose delete all.
Not sure what else you’d need to clear the entire plate at once.
