Hi maker’s,
I need help to add a threaded compartment to an existing 3d file.
For example a esculper of a cat or dog and on the bottom add a screw-on lid to stage stuff inside.
It´s possible ?
Hi maker’s,
It´s possible ?
Sure it is.
Create the thread/compartment that you want (as a male thread) and import it as a “Negative Part”. Alternatively you use the Boolean mesh to subtract the thread/compartment from the model.
I can create with the bambu lab slicer ?
The threaded geometry will need to be created with something outside of Bambu studio. The compartment can be created within Bambu Studio using a “Negative Part”.
https://wiki.bambulab.com/en/software/bambu-studio/subtract-a-part
low-poly-cat.3mf (6.4 MB)
I ´m try to follow the step but and cant create the hole with the screw in this STL, like to and like pig bank on the bottom, can help how to do, whit this exemple thanks
