How to do a cut with a "perfect edge
New to Bambu studio and playing with the cut object capability…
Is there a way to do a cut without getting a smooth edge on the two objects when assembling them?
Its as if the edges have a micro bevel.
thank you.
Are you referring to the resulting print from a cut model? If so, it is a result of the molten plastic is not going to be perfectly flat, square, etc. There will always be a visible seam.
Yes, I’m referring to that. Makes it challenging to maintain the quality of a single print I suppose.
Thanks for the response.
The reason layer lines are visible is because each layer is not flat on top with straight vertical sides. If you zoom in on the preview image in the slicer it is shown that way. You can probably lessen the effect by using thinner layer heights.
