How to Do - Multi Z Offset Settings for Filaments & Bed Plates
  1. Click the edit preset for the printer
  2. Click the Machine G-code tab
  3. Now scroll down and look for this G-code and replace it with the new
    Multi Z Offset Settings G-code
Updated V2 1/26/2024
;==== Multi Z offset settings 3DTech V2 ========
{if (filament_type[initial_no_support_extruder]=="PETG-CF" && (curr_bed_type=="High Temp Plate" || curr_bed_type=="Engineering Plate"))}
    G29.1 Z{+0.05} ; for PETG-CF and High Temp or Engineering Plate
{elsif (filament_type[initial_no_support_extruder]=="PETG-CF" && (curr_bed_type=="Textured PEI Plate"))}
    G29.1 Z{+0.04} ; for PETG-CF and Textured PEI Plate
{elsif (filament_type[initial_no_support_extruder]=="PETG" && (curr_bed_type=="High Temp Plate" || curr_bed_type=="Engineering Plate"))}
    G29.1 Z{+0.02} ; for PETG and High Temp Plate or Engineering Plate
{elsif (filament_type[initial_no_support_extruder]=="PETG" && (curr_bed_type=="Textured PEI Plate"))}
    G29.1 Z{-0.01} ; for PETG and Textured PEI Plate
{elsif (filament_type[initial_no_support_extruder]=="PLA-CF" && (curr_bed_type=="High Temp Plate" || curr_bed_type=="Engineering Plate"))}
    G29.1 Z{+0.03} ; for PLA-CF and High Temp Plate or Engineering Plate
{elsif (filament_type[initial_no_support_extruder]=="PLA-CF" && (curr_bed_type=="Textured PEI Plate"))}
    G29.1 Z{-0.01} ; for PLA-CF and Textured PEI Plate
{elsif (filament_type[initial_no_support_extruder]=="ASA-CF" && (curr_bed_type=="High Temp Plate" || curr_bed_type=="Engineering Plate"))}
    G29.1 Z{+0.05} ; for ASA-CF and High Temp Plate or Engineering Plate
{elsif (filament_type[initial_no_support_extruder]=="ASA-CF" && (curr_bed_type=="Textured PEI Plate"))}
    G29.1 Z{+0.04} ; for ASA-CF and Textured PEI Plate
{elsif (filament_type[initial_no_support_extruder]=="ASA" && (curr_bed_type=="High Temp Plate" || curr_bed_type=="Engineering Plate"))}
    G29.1 Z{+0.01} ; for ASA and High Temp Plate or Engineering Plate
{elsif (filament_type[initial_no_support_extruder]=="ASA" && (curr_bed_type=="Textured PEI Plate"))}
    G29.1 Z{-0.03} ; for ASA and Textured PEI Plate
{elsif (filament_type[initial_no_support_extruder]=="PA-CF" && (curr_bed_type=="High Temp Plate" || curr_bed_type=="Engineering Plate"))}
    G29.1 Z{+0.05} ; for PA-CF and High Temp Plate or Engineering Plate
{elsif (filament_type[initial_no_support_extruder]=="PA-CF" && (curr_bed_type=="Textured PEI Plate"))}
    G29.1 Z{+0.04} ; for PA-CF and Textured PEI Plate
{elsif (filament_type[initial_no_support_extruder]=="TPU" && (curr_bed_type=="Textured PEI Plate"))}
    G29.1 Z{-0.01} ; for TPU and Textured PEI Plate
{elsif (curr_bed_type=="Textured PEI Plate")}
    G29.1 Z{-0.04} ; for Textured PEI Plate
{else}
    G29.1 Z{+0.00} ; for High Temp or Engineering Plate
{endif}
  • You can edit the Z heights or change the filament types as needed or add more filaments to the list.
  • You can look at the g-code and see the offset added for the plate type and filament type selected.
PETG-CF Multi Z Offset Setting @ .05
Multi Z
ASA Multi Z Offset Setting @ .01
ASA Z
PLA Z Setting @ 0
PLA Z
Let me know how it works out for you.
Happy 3D Printing :smiley:
Great, I had the same idea as you.
In particular I would like to set a lower Z offset when printing PetG on carbon effect type plates. For more grip on the surface. PLA remains well attached, PetG does not.
I want to make sure I understand this.
So adding this to my start G-code will adjust the z offset that the machine auto figures when it does the mesh? Or does this tell the machine exactly what the z offset should be according to the Material Type and Plate?
New P1S owner. PLA was beautiful out of the box, PETG and ASA, not so much. I knew it was Z offset issues and found this thread looking for the answer. You saved me a good bit of work @3DTech. Thanks much!
If I want to modify the offset of the cold plate, do I have to modify these lines?
I have copied and replaced everything and I get this error.
I was getting similar errors. It seems to be something with the IF command. I just used it without the IF, and it works fine. I change it manually each time when needed:
G29.1 Z{-0.05} ;
(… type it in, don’t copy/paste from here.)
Just to confirm, a negative -Z offset will be closer to the print plate (More squish) and a positive value will increase +Z offset and increase the height over the print plate (Less squish)??? I want to confirm before I change my offsets. Thanks
Question why change the offsets?
Generally, a Bambu printer will reliably determine the correct offset. If more squish is needed, calibrate and adjust the flow rate.
