How to escalate terrible support? New P1S unusable since delivery
Yea I did all these past 2 weeks. Since they didn’t reply last 2 weeks, I did everything I could do. I removed and reinstalled the wifi module. Removed the P1S from Bluetooth devices on my phone every single time. I run it on 2.4ghz and even change the password to very simple password. It originally worked when I got the new device, but the issue was no camera, no led or no USB port working. It connected to wifi fine.
I had a problem with the hotend getting clogged just after the extruder gears. When I took the hotend apart I found the problem. Reassembled and plugged the wires back in and after that had no luck getting it working. I reset the machine back to factory settings, replugged the wires a dozen times. Wrote a ticket to BBL etc. They responded that the wires were most likely not plugged in properly. In the end that was what it was! I never had plugs like they have before. I now learned to move the printer to where there is good lighting to see what I’m doing.
Printer has been running like a Swiss watch ever since.
You can try to connect it to Wifi with a file on the SDcard.
Its hidden in their wiki:
P1 series micro SD card network configuration guide
