How to force Studio to Slice what I want
This is so frustrating when I am getting red “error” message that prevents me from slicing.
Is there a general way to simply turn off this feature in bambu Studio.
This time I wanted to do multi material print using PLA nad PA-CF
And apparently I am “not allowed to”
Cris.
you can get around tpu being not allowed in the ams by saving it as another filament type and modifying it’s setings to match tpu settings. You can try that w PA-CF but iirc cf infused filaments are harsher on ams components so after some time you might need to inspect your filament pathway in the ams for potential worn down items. I am assuming by multimaterial printing you are planning on using the ams and not changing them manually from ext. holder
What is the error message?
PLA and PA-CF filaments seem to be an unlikely combo, with greatly different temperature, speed, cooling, and shrink specs.
Error says these materials have different shrink.
But strange thing. I was trying whole morning, and even got around the problem by making PA-CF emulate PLA and overriding material setting in AMS. and even got half way through print.
Now suddenly this error is not showing anymore even if I change back to real PLA.
So now I am totally stuck in trying to understand what is going on in the Studio.
As for this being “unlikely combo” this is whole point so they are easily separable after print.
Should I see this error once more will post screenshot.
Cris.
Here it is back again
One hint,
This disappears if print order is set to “by object”
So totally irrelevant setting.
