How to get rid of that line?
Hi,
I just start 3d printing and must say, I failed at that one.
Every time I print flat surface with some shape in i’m getting this line
I am using Bambu Studio with standard settings. Quality looks good but this line coming out when printing top layer as monotonic line.
Like I said, i’m a newbie and dont even know how to name that :wink:
I’ll be appreciated if anyone can help me
Can you share a 3mf with us so we can view your model and settings?
Looks like the seam to me.
podstawka.3mf (811.5 KB)
I just print one of the models from makerworld with that model setting and get same issue
Using ZIRO silk filament at 210 degree
Like @lion7718 mentioned, that’s the seam. In the slicer you can change it to “random” if you don’t like the line. There is also a new “scarf” seam but I haven’t really experimented with it much.
@PrinterMcgee @lion7718 @MalcTheOracle Thank You guys. I will test it tomorrow
I use a lot of Zero filament, Silks should be printed at 215*…JMO
Be aware the release issued two days ago (v01.10.00.89) of Bambu Studio turned on scarf by default.
Scarf is a great feature.
However, it turns out they hadn’t tested as many models as they should have. Instant reports of models failing with very visible issues were found.
The very latest release issued today (v01.10.01.50) turns off the Scarf feature by default until they fix it.
So, two things.
  1. I thoroughly love the new scarf feature.
  2. It ‘may’ be the cause or the solution.
If it is on, try turning it off, if it is off, try turning it on.
