How to lower Z in first layer to add squish?
Hi - I’m trying to make the first layer be a bit more pressed into the plate (normally would use live-adjust Z for this on a Prusa). Is there any way to do it? I’m using the Engineering Plate.
I found some other posts about it previously but there didn’t seem to be conclusive answers. The closest I found is this thread suggesting the way to do add Z-offset with code, which I am trying to do but the results seem the same - so I’m not sure it’s working:
Maybe I’m putting it in the wrong place? Or it’s not the right thing? Any help appreciated. TY!
Figured it out. For posterity, it goes into the Machine Start G-code section.
;===== for Textured PEI Plate & Engineering Plate , lower the nozzle as the nozzle was touching topmost of the texture when homing ==
;curr_bed_type={curr_bed_type}
{if curr_bed_type==“Textured PEI Plate”}
G29.1 Z{-0.04} ; for Textured PEI Plate
{endif}
{if curr_bed_type==“Engineering Plate”}
G29.1 Z{-0.02} ; for Engineering Plate
{endif}
This was super helpful and more info and instructions can be found there: Printables
I get this issue with your code. are you able to run yours with engineering plate
Hmm yeah it works for me. Make sure you’re including the first line, it seems like it’s not recognizing the variable?
could you try slicing a file with engineering plate selected ? Would be much appreciated
The error maybe related to the " sign. If you have copied it from the browser, it maybe replaced with a simular one. Try to replace the " signs by typing it with the keyboard.
I would be careful with this
Thank you. that fixed it. Now to see my nozzle in air issue gets fixed.
What I mean
With the redundant bed leveling I fail to see why this is even needed. Have you done a calibration recently?
We have three X1-C, never saw this problem.
I find better first layer adhesion and appearance with a bit of squish for petg on engineering plate.
hi , how can I lower z offset using Cool plate bed?
Why not increase first layer width? It would give the same effect I think.
Thank you andrey this is exactly what I needed.
I was having inconsistent layer lines on random areas on the bottom surface - all I wanted was a smooth, consistent surface - it wasn’t consistent - not matter what I did - I adjusted temps, widths, flow
I just needs more “squish”!
Bambu needs to add this to the hardware menu….like it has been for years with other printers.
I usualy set PEI textured build plate - it already has -0.4 Z height when ever i use the BiQu Frostbite plate to get nice first layer.
What did you end up having to do to get the first layer to look like your second photo?
If you use Orca slicer…
Increase the “bottom surface flow ratio” value to something like 1.1.
Located under…Quality/Walls and surfaces
-Uman
