How to make an object hollow
I hope this is the right place to ask for help….. I am completely new to 3D printing let alone designing anything.
I have a design I am trying to make hollow. I would like it to be a planter. I managed to get the pouch of the kangaroo open but I need the print to be completely hollow. A photo of my first design is attached. I will scale it up as I get the design right, I just don’t want to waste filament.
After some research I tried using vase mode but I keep getting a message to use supports but you can’t use supports in vase mode.
No you dont. The object will never print correctly without infill aka internal supports.
What you need to do is model in the cavity you need. Might even be able to use a negative part.
Can I just make the bottom part hollow?
The most important question first: Why do you want it hollow?
  • If you just want to save filament, you can do that via the infill settings, where you can specify to use less, but using none at all is not recommended.
  • Do you want it hollow for a specific purpose, e.g. to fill it with potting soil? Then you need a program that can edit mesh objects, such as Blender or Meshmixer.
Yes, I want to fill the bottom part with potting mix.
I think it would be most productive for this base object to:
  1. model what you want the hole to look like. Tinkercad is probably a good option. Semicircle/more ovoid?
  2. Use that hole as a “Negative Part” to the base model. Position it in so that it doesnt poke out walls, and slice.
You just want a bigger hole, right? not actually fully hollow (including up in the body??)
Yes, a bigger hole… not completely hollow. I’ve I have tried blender so I will look at tinkercad. I am sure once I figure out how to use the right tool in the program it will all fall into place.
in my 50’s, never used any programs other than email…. lol
Building on this great comment, I would make it even simpler by just adding a negative sphere. This area will then not be printed. If there is soil on it, no one will be able to see how accurate it is anyway.
Of course, the variant described by Bullocks is better, but if you just want to test it quickly.
Please note! PLA is not watertight. It can leak if you water your soil too much!
Thanks for this tip. I did see those settings but for the life of me I could not get it inside the print so I will have to use practice and patience.
I have ABS and ASA I think it is called. My son gave me a diamond tip nozzle for Christmas so I believe I can use even hardier filament in time.
we are in a hot sub tropical environment so anything for outdoors should not be ASA?
Also… another question. I have ABS and PLA support filament which I will probably not use in the near future… can I use that for my practise prints to save my filament. I am sure I read somewhere that someone did that for their practice pieces.
I wouldn’t do that. There’s a big, bold red warning on the homepage about this.
Thanks… noted… will not use it for practice.
I have a feeling I may have read that at some point hence my confusion.
Thank you very much… :smiling_face_with_three_hearts:
I tried in tinkercad but my file was too big so I used your suggestion and it worked.
I have more adjustments to make but I think I can figure it out from here.
I just want to say thankyou to everyone that gave advice, I am so pleased to find such a kind community.
For those who want to make a model completely hollow, download Chitubox basic from their official site. Basic is free and that’s all you need.
Chitubox is really a resin slicer but you don’t care for that particular application. Just open your stl, no need to select printer or design a plate to fit, just select hollow in the top menu icons, set your wall thickness and apply.
Save your hollowed model as a new stl, done.
Hi Philch, Just want to say thankyou as I seem to be having great success with this program… not yet finished but it appears to be the easiest out of all the programs and does exactly what I need it to do…
My son has a resin printer so it has even inspired me to try his printer later.
Thanks again.
For anyone else coming across this thread… MeshMixer includes a feature specifically designed for making 3D prints hollow inside.
I have a goofier way to do it, but it can be a little tricky and someone else probably has a better way to do it.
I googled this same issue, because I typically just use the shapes available like cylinders and cubes, etc. and I came across this thread.
Then I thought about something I had done the other day that was kind of unrelated, but worked. Save your kangaroo under another file name (let’s say Kangaroo2.3mf), then cut the head and tail off of it.
Shrink it by 20% and save it.
Open up your original file. Then add negative part and where it says load, click on Kangaroo2.3mf. It will load your file as a negative part that you can position inside your solid kangaroo that will follow the contours exactly.
Oh… this is actually a really good idea. I will definitely give this a try as I think it will give the look I am aiming for.
Responding specifically to this point…
ASA is actually ideal for outdoor settings. It has much higher UV resistance than ABS, with slightly better heat and water tolerances.
