How to manage printer presets on the Prepare tab
The Bambu Wiki page “How to Create Custom Preset” describes how to create a Printer “System Preset” definition.
The Bambu Wiki page “Create a Custom Printer or Nozzle” describes how to create a Printer “User Preset” definition.
Neither page provides a simple list of operations needed to add or delete a printer User Preset or System Preset. Hopefully this topic addresses these issues.
There are 2 types of printer definitions:
  1. A “User presets” printer definition.
  2. A “System presets” printer definition.
The Bambu Studio “Prepare” tab, “Printer” section, printer dropdown list.
In the Bambu Studio “Prepare” tab, “Printer” section, select the printer drop down list to display the available printer preset definitions, e.g., “Bambu Lab P1S 0.4 nozzle”. There are 2 preset groups and 2 commands shown in the list.
“------ User presets ------” List of all user defined printers.
“------ System presets ------” List is created initially when you install your printer, but entries can be added or deleted using the “------ Select/Remove printers(system presets) -----” command…
“------ Select/Remove printers(system presets) -----” This command allows you to add or delete System Preset printer definitions.System Preset printer definitions are based on printers that have been characterized by Bambu Lab.
“------ Create Printer ------” This command allows you to create a User Preset printer definition.
1. To create a “------ System presets ------” printer definition:
Note: This option only allows adding or deleting printers from the “------ System presets ------” list.
1.1 Select the “------ Select/Remove printers(system presets) -----” command. Selecting this option brings up the “Printer Selection” dialog box, which displays a list of all the Printer/Nozzle options that Bambu Studio has default settings for.
1.2 If your printer is in this list, click on the nozzle size(s) for the printer
1.3 Click on the “Confirm” button. This will add the printer(s) to the “------ System presets ------” list
2. To delete a “------ System presets ------” printer definition:
2.1 Select the “------ Select/Remove printers(system presets) -----” command. This displays the “Printer Selection” dialog box.
2.2 On the Printer Selection dialog box, uncheck the printer/nozzle that you want to delete.
2.3 Click on the “Confirm” button. This will delete the printer from the “------ System presets ------” list.
3. To create a “------ User presets ------” printer definition:
Note: This option only allows adding or deleting printers from the “------ User presets ------” list.
Note: The Bambu wiki for this option is here.
3.1. Select the “------ Create Printer ------” command to display the “Create Printer/Nozzle Create Printer” dialog box.
Note: There are 2 “Create Type” options on the “Create Printer/Nozzle Create Printer” dialog box: “Create Printer” and “Create Nozzle for Existing Printer”.
3.2 Create Nozzle for Existing Printer:
3.2.1. Checking the “Create Nozzle for Existing Printer” checkbox, reformats the “Create Printer/Nozzle Create Printer” dialog box, to only show the “Select Printer” and “Nozzle Diameter” widgets.
3.2.2 For version 1.8.4.51, the “Select Printer” dropdown does not appear to work. No list of printers to select from is displayed! And clicking on OK, displays the message “You have not yet selected the printer to replace the nozzle, please choose.” The only way out is to select Cancel or close (X) the dialog box. Is this a BUG? Or did I miss something?
3.3 Create Printer:
3.3.1 Checking the “Create Printer” checkbox displays the (default) “Create Printer/Nozzle Create Printer” dialog box.
Note: “Bambu” or “BBL” is not in the list displayed by the “v Select Vendor” dropdown list box. It appears that this list is a superset of the “------ Select/Remove printers(system presets) -----” defined options. I guess there is an expectation that Bambu printer definitions are created using the “1. To create a “------ System presets ------” printer” method, described above.
Note: The “Create Printer” checkbox is selected by default.
3.3 2 Set the Nozzle Diameter of your printer.
3.3 3 Enter the custom printer vendor and model names.
3.3.3.1 Check the “Can’t find my printer model” checkbox if your printer is not displayed in the “v Select Vendor” dropdown list and enter Printer Vendor and Model names.
Note: The names entered in these fields are concatenated and displayed as the name of the printer in the “------ User Preset ------” list.
3.3.4 Enter the Printable Space (Print Bed width and depth), Origin, and Max Print Height (Z) for your printer. These values will override those defined by the “v Select Vendor” selection in step 2.5,
3.3.5 Then click OK to display the “Create Printer/Nozzle Import Preset” dialog box.
Note: The “Create Printer/Nozzle Import Preset” dialog box is shown here.
Comment: Above the “Printer Preset” “v Select Vendor” and “v Select Model” dropdown listboxes, it says “Create Based on Current Vendor”, which would seem to imply that the “V Select Vendor” and “V Select Model” dropdown list boxes apply when the “Create Based on Current Printer” checkbox is checked. It doesn’t. You always need to select Vendor/Model to use as a starting point from the list that Studio knows about. Note that Bambu (BBL) is displayed in this list.
Note: The Filament Preset Templates and Process Preset Templates will be populated after you select a Printer Vendor and Model.
3.3.6 Select the Vendor/Model that ‘best matches’ your printer. Don’t worry, you can adjust the settings later if your printer is not an option in the “v Select Vendor” or “v Select Model” dropdown list.
3.3.7 You are required to select at least one of the displayed Filament Preset Templates and Process Preset Templates.
3.3.8 Clicking on the OK button brings up the “Create Printer Successful” Message box.
Note: The “Create Printer Successful” Message box is shown here.
3.3.9 Here you can click on the “Printer Setting” button to bring up the “Printer Settings” dialog box.
Note: Using the “Printer Settings” dialog box, you can customize any of the Presets that were not set correctly by the Vendor/Model selected in step 2.5.1.
4. To delete a “------ User presets ------” printer definition:
4.1 Select the “User Preset” in the “Printer” dropdown listbox.
4.2 Click on the “Click to edit preset” button (to the right of the listbox). This displays the “Printer Settings” dialog box.
4.3 Click on the “X” icon (between the Save and Search icons) on the “Printer Settings” dialog box. This displays the “Bambu Studio - Delete” message box. Do not use the ‘X’ on the dialog box title bar (top right)!
4.4 Click on the “Delete” button.
4.5 The “Printer Settings” dialog box then switches to the next Printer. Close the dialog box (“X” on the dialog box title bar (top right)).
5. “------ User presets ------” names:
The name used to save a User Preset definition will be displayed as the name of the printer in the “Prepare” tab, “Printer” section, printer drop down list.
e.g. If you had 3 Bambu printers with device names “Moe”, “Curley”, and “Larry” ( as displayed on the Device tab), you could save User Preset Definitions with the same names for the respective printers. And these names would then be displayed in the “------ User presets ------” list.
Note!: Selecting a printer preset on the “Prepare” or “Preview” tab (e.g. Moe) does not make that printer the “current” printer. e.g., Filament Sync is always performed for the “current” printer, irrespective of the printer name displayed on the “Prepare” tab. The current printer must be set on the “Device” tab by selecting a “My Device” or “Other Device” option (in the upper left corner).
NIce, detailed, descriptions. :+1:
Maybe you could explain why there is a distinction between User and Custom filament presets, advantages/disadvantages, when/why to pick one over the other?
Using a single printer with no AMS, I have not found the reason to have any Custom presets.
The differences between User and Custom filaments are listed below. But the quick answer is… Custom filament definitions can be assigned to multiple Printer definitions (System Presets) while User filaments definitions are only available to the Printer that they were created under. I would recommend using Custom filament definitions.
Note that the Printer area on the Prepare tab, does not reference a physical printer. It references a logical printer. For instance, the default printer definition when you unbox it may be “Bambu Lab P1S 0.4 nozzle”. If you change your extruder nozzle, you can define a second logical printer (System Preset), e.g., “Bambu Lab P1S 0.2 nozzle”. Now any tweaks that you made to your (Custom) filament settings for the 0.4 nozzle would be available if you switched your nozzle back. But both logical printer definitions apply to the same (your only) physical printer.
Custom filament definitions can be copied to another printer definition. User definitions cannot. You may want to do this if you developed a sweet filament definition using one nozzle and you want to try it with your new nozzle. Otherwise you will need to physically transcribe all the changes,
Any User settings made under one logical Printer definition, cannot be seen by another logical Printer definition.
Here are some more details…
If you click on the Prepare tab, Filament, “Set Filaments to use” button (the gear icon).
Prepare tab, Filament, Set Filaments to use button
It brings up a dialog box with two tabs: System Filaments and Custom Filaments. Let’s call this the Set Filaments to use dialog box, because it doesn’t have title.
System Filaments:
  • “Created” using the Set Filaments to use dialog box, System Filaments tab to select the filament from a read-only Bambu Lab maintained set .
  • “Deleted” using the Set Filaments to use dialog box, System Filaments tab, and unchecking the filament definition.
  • Are listed on the Set Filaments to use dialog box, System Filaments tab.
  • Are displayed in the Filament dropdown ------ System presets ------ list.
  • Are global, that is, available to all Bambu Studio Printers.
Custom Filaments:
  • Created using the Set Filaments to use dialog box, Custom Filaments tab, Create New button.
  • Deleted using the Set Filaments to use dialog box, Custom Filaments tab, Edit button, Edit Filaments dialog box, Delete Filament button.
  • Are listed on the Set Filaments to use dialog box, Custom Filaments tab.
  • Are displayed in the Filament dropdown ------ User presets ------ list.
  • Are assigned to a Printer (System Preset) definition, e.g., Bambu Lab P1S 0.4 Nozzle.
  • Can be copied to another Printer definition.
User Filaments:
Prepare tab, Filament area
  • Created by editing an existing filament, e.g. Generic PLA, displayed on the Prepare tab, Filaments section using the Edit button next to it, and Saving the change (with the name of the new filament definition).
  • Deleted by selecting the Edit button next to the Filament definition on the Prepare tab, Filaments section to bring up the Filaments Settings dialog box. Then pressing the ‘X’ button (between the Save and Search icons) on the Filaments Settings dialog box. Delete User Preset filament
  • Are NOT listed on the Set Filaments to use dialog box, Custom Filaments tab.
  • Can not be copied to another Printer definition.
I have the same issue, and I am so frustrated; Bambu studio is the worst program I have ever seen. i have no idea how to resolve “You have not selected a printer or preset Yet, please select at least one”
I have already two printers in my list , can someone please help me or I will throw that printer
P1S
X1 Carbon
So I perhaps saw this issue to I was trying to add a custom filament and I got the “You have not selcted a printer or preset yet, please select at least one”. There was nothing in the drop down box to select a preset from.
Turned out it was because I had selected a filament type that I had none of the other profiles loaded for. In this case I was trying to make one for Prusament ASA and I didn’t have Bambu or Generic ASA Selected, so when I selected a type of ASA nothing could appear to populate those boxes. I went back and added those profiles, hit confirm, and closed out, then went back to the custom page and could select the Generic ASA to start from.
I know this is an old thread, but there aren’t many discussions as “on point” as this one. I have customized user presets for each of my printers. But I want them to be the default process settings when I choose the printer? As it stands now, when I choose a printer, I get the default Bambu 0.2 mm setting. How can I make my user preset be the default?
