How to modify an object
Hi guys
I want to ask if is permitted and if it is possible to download a 3mf from maker world and the modify it to be sure tha this delivers the quality i want, especially for assembly parts, since i see that usually if you just assembly the parts the object is very sensitive, so i prefer adding some bolts and glue
It’s always allowed for personal use.
However, if you mean re-uploading the improved version to MakerWorld, you’ll need the designer’s permission. Fortunately, every designer specifies on the model page whether it’s allowed or not.
Scroll down and take a look at this field that the designer provided - on the right side.
For example, not allowed:
Here, for example, allowed, but you have to credit the original creator:
You can also click on the field to get more information, what the designer allows or does not allow.
