Hello print friends,
All worked great while printing a large sculpure in interlocking pieces on the H2S. Suddenly, I got prints with noticeable polygons. Keep in mind that polygon density is roughly the same across all pieces of the model. Firmware version 01.03.00.00, where arc fitting is turned off by default. Same settings for both pieces in the photos. So far I’m loving the machine, and I ordered a second one to reduce time for my large projects.
I hope any of you experts can give me some input.
Thank you!
It might be easier to attach the 3mf.
Do the “polygons” show in the model preview page?
Thank you for your response! Attached are the two files (there are 40 more). I’ve also attached a small exploded view showing the part in question with the polygons, and the print looks great.
Chair flattened_PART_005_RIGHT_LOWER_FRONT.004.3mf (792.6 KB)
Chair flattened_PART_005_RIGHT_LOWER_BACK.006_FRONT.005.3mf (123.2 KB)
Thanks. Ill take a look real quick.
The Polygons are in the file. Either export the file from the program it was created on with a better export option or use the built in feature on bambu which can help reduce the polygons. NOTE this sometimes messes up other portions of the part. So check it before and after.
Right click on the bambu studio
Just export as a step file from your CAD tool, that will make the steps disappear. You have a stl-File in the model, that is not very good at roundings and round corners.
Subdivision helps, but destroys the integrity of the model. Designed in 3DS Max. It has a real organic complicated flow that is a real pain to do in a CAD program like Rhino 3D. At this point, the model is already sliced and halfway printed, and i think I will have to do some heavy post-processing.
Yep, thats why I said check before and after. On some files it works great. On others not so well.
I will try that next time. Thanks.
@MotoGP11991 is right. Props for being faster.
With the lower resolution of the file itself, this is going to be hard to get rid of. And impossible with just slicer settings.
Is this file yours or did you download it from somewhere?
What is the purpose of the file? If you are going to be sanding and painting then this is not that big of a deal?
If you want to, but a lot of effort, you can import the files into blender and do more subdivisions to get more resolution.
I used 3DS Max and Blender
Unfortunately, that won’t work for polygon (sub-d) modeling
How many of these are you making? I ask because a bit of sand paper will fix that no problem.
Also I presume you know this but blender has plenty of mesh smoothing tools. But I suspect you are better with blender than I am, so I am not going to comment further.
This is my design; it wasn’t downloaded. I was very happy with the first few (15 pieces) prints until I had this surprise ![]()
Nice.
Out of curiosity, can I ask what you are making?
I am so jealous of anyone that can use blender. I am used to Solidworks and having a play with blender a few weeks ago makes me more than happy to stick with my silly little shapes/cutouts. SW feels like cheating with how easy I find it to use in comparison.
You are right, sanding will do it, but the sculpture is over 1m high and almost 1.80m long. Roughly 1.5 million polygons. Blender lets you auto smooth, but that is only for the viewport, not the STL file.
I think I have something to read in the evening. Thank you for the feedback. I really thought step catches all the flaws.
There are mesh modifiers that can smooth a mesh, but they have varying degrees of success and are hard to use. I recommend asking on a 3d mesh modelling site or the blender groups.
