How To: Print with Translucent Filaments
[Sorry if this is in the wrong category, please feel free to move.]
I’m putting this post together to serve as a reference to configuring your translucent prints for better results.
Getting optimal results will depend on the layers fusing together and cooling slowing to allow for crystallization. This will optimize molecular arrangement and allow for greater translucency.
The following should be a good starting point for non-Bambu filaments:
Global Settings
  1. Set print speed to 20mm/s
  2. Set layer height to 0.1mm
  3. print without top or bottom layers, as well as without walls
  4. set infill to 100%
  5. set infill to have a single direction
  6. use a hot, smooth build plate
  7. use the the largest nozzle possible that still satisfies your quality requirements
  8. set all line widths to [nozzle width] * 0.9
Filament Settings
  2. turn off all fans
  3. increase the temperature as high as possible without burning or bubbling; for PETG this might be between 260 and 270C
  4. set flow rate to 1.01
  5. make sure PETG has less than 15% humidity
Custom Adjustments
  1. after slicing review the layer time view and try to keep layer times below 80s (need to verify the exact threshold)
  2. after print completion let it cool slowly on the printer
The following test model should have all the above settings:
Further Refinement
  • minimize top layer extruder tracks
  • improve 0.2mm nozzle results
  • verify layer time threshold to promote fusing of layers; may be able to compensate higher layer times with higher nozzle temps
Resources
Thank you for this, Mike! I’ve got a project where I’m printing a kind of lens and need it as clear as possible but wasn’t hoping for much. This may make it look much, much better.
It’s not as easy as with PETg filament but with correct setting it can be done .Make sure nozzle and heat bed is at correct temperature and heatbed is leveled up correctly (people always forget to check minor things and end up having unexplained issues :wink:)
I’d like to contribute to science with these test pieces:
More pics and info here: Surface Finish Test Strips - Multi-Speed by KYZ Design MakerWorld: Download Free 3D Models
