Hey there!
I recently bought from bambu a smooth plate with a set of effect sheets, i am now trying to peel off the effect sheet that came pre-installed in the plate and it’s impossible to do it.
I tried to use the scraper tool like the FAQ suggests but it is also removing the paint from the plate.
My last attempt was to print a 2mm height cube covering 100% surface, so some of the glue came out with the print, but i think the base of the sheet is still glued to the plate
Any ideas on how to fix this?
I would try with some acetone in a corner.
That helps
it;'s gonna take me hours (or days) to get the whole thing off and im getting dizzy from the acetone smell but it’s progress haha
thanks!
Typical resommendations are to pop the plate in the freezer before trying to peel it off and to use Limonene as a solvent.
In my case, I forgot the former but did use the latter. Still took just over an hour per side with plenty of paint lost… Working fine now though
Edit: And keep some band aid pre-cut and in easy reach.
use a solvent like acetone or glue removing agent
