How to set timezone / system clock
Got a P1S for Christmas :smiling_face_with_three_hearts:
I noticed that the time-laps videos as well as the files on the SD-card are labeled with the wrong timezone, about 6 hours into the future.
I didn’t find any time settings on the printer or in the apps.
Any ideas?
Thanks :hugs:
I contacted Bambu Lab support about this. The printer gets its time from the internet using NTP.
However, how exactly the printer determinate in wich timezone it is located is not clear to me, since only “Europe” can be chosen.
I’m waiting on a reply about that from support.
My printer is 8h ahead of my timezone for some reason.
Might be an Austria / Australia bug, time would fit :smile:
I figured out the issue:
During the setup, the location of the smartphone used sets the timezone. I had „Privat Relay“ activated on my iPhone and that apparently placed me in Australia :kangaroo:
Doing another Factory Reset with Privat Relay disabled solved the issue.
FYI: Filezilla still displays +1 hour, not sure why but the files on the SD card are now correct. You can set an offset in the Filezilla server settings to correct this.
Also when doing back-to-back factory resets, make sure the bed is positioned in the middle or the bottom of the printer before initiating. If the bed is in the top position (where it will be after a reset), it will still move up during the new reset process and slam into the nozzle.
No damage luckily, but still :confounded:
I don’t want to go through the factory reset.
The time zone setting might be implemented later.
I also can’t change my username. I only have a number as my username.
Otherwise, it’s great software and hardware.
