Is there a way to swap from Beta to normal without having to uninstall and reinstall Bambu Studio every time for Beta testings? It won’t let me upload print profiles in Beta.
If it’s currently not possible, can you enable it for future Betas? It’d help us to save time and encourage more people to test Beta versions of Bambu Studio.
It’s on purpose, if it’s made with beta BS, and a beta can have bugs nobody wants a model to inherit those bugs and if there are new features that make that model printed as intended a user may have a failed print if he is not on beta using this particular feature
If you wish, you can have a release version installed alongside a beta version. They use separate configuration directories and shouldn’t interfere with each other. One can even run them side-by-side simultaneously (well, at least on Windows, haven’t tried that on Mac or Linux, but in theory). Be sure to uncheck the “beta version updates” option in Preferences for the one you wish to keep as release-only.
The only possible caveat is if you store custom profiles on the cloud… I’m assuming whichever profile version is saved last will then be active for all Studio instances tied to that account and will sync back to whichever other version(s) of Studio are used. Honestly I’m not sure how/if they handle that, if at all… I don’t use cloud sync and set up my own mapped/shared folders to share my custom profiles between Studio versions.
The zipped “portable” version will use the same configuration folder as an installed version (of the same type, beta vs. release). There is no practical difference besides the installer program unzipping it for you, essentially. To make it truly independent, one needs to use the (new) data config location features I described and linked to (I know the Wiki article is still on my fork, but it’s one of the things they asked me to write up and then ignored – the info does apply to official BL version).
Bambu Lab continues to make some of the most asinine decisions I’ve ever seen lately. I don’t usually mind being a tester, but when things consistently go so horribly wrong that I can’t use features I rely on (which shouldn’t have even been touched!)… I’m much less inclined to try these things out.
I regularly use the Beta versions as they become available. I typically wait until the regular version comes out and then load the things I want to upload. The two versions tend to leapfrog each other every couple of weeks or so.
Though you’re downvoted, you got a point. Bambu Studio and firmware updates aren’t the best and cause at least a different issue with every new release. Nonetheless, we love the brand of Bambu Lab, thus we want it to improve if possible. I read about a guy who scrapped the bed upon updating its H2 firmware, but they refused to cover it, so he’s not updating its firmware anymore. I had an instance in A1, where the toolhead looped in a jerk, so I submitted a ticket, but they’re unable to solve it. Luckily, it reset by turning it off/on and hasn’t repeated since. Also, firmware updates have failed me twice, i.e. the first ever and last one, so I had to insist on until it updated, because it was uploading the new firmware up to 25% before failing. I think they rush software updates, which is quite annoying every two weeks, and they should be down to twice a year. This way, they’d have time to fix errors, and consolidate patches, which otherwise make us mad. I don’t know whether people agree or not, but it’s how it is. Thank you for your comment.
This is a way to avoid wasting time debugging, but without your input they won’t be able to foresee all scenarios. Normally, printers work without further issues though.
Yeah, I know what you mean. I’ve seen the Bambu Studio update prompt, where it says you can use a separate configuration folder, but I’ve found the instructions nowhere. This could be really helpful in order to avoid installing/uninstalling the software every time a Beta doesn’t work.
You provided accurate instructions, though technical, and I still don’t know what to do next: It says I should have a separate configuration folder (BambuStudioBeta) beside the main one (BambuStudio), but this is how it already is—I haven’t modified anything—. However, how do I switch between them? If I click the BambuStudio icon, it launches the current installed version, either the main or the beta one, so it doesn’t let me choose. Besides, there’s only one app I can make a shortcut from. Help, please.
I’m not entirely sure what I’m looking at (also not a regular Mac user).
But Mac .dmg files (as downloaded from Studio GitHub releases) are just compressed archives (roughly speaking). When you open (or “mount”) one, instead of dragging the contained BambuStudio.app to your Applications folder (or choosing to “install” it), drag it to some other location (a different folder). That way you could extract one version to folder A, and another to folder B, and run them independently. Or keep a stable version in Applications folder and beta(s) in other folder(s).
(I’m not sure MacOS shows the .app extension by default, so the DMG contents may just show “BambuStudio”)
By default when you run those, they’ll use the corresponding configuration storage location,
“Users/<USER_NAME>/Library/Application Support/” in either “BambuStudio” or “BambuStudioBeta” subfolders.
Optionally, if you create a folder named “configuration” next to (in the same folder as) BambuStudio.app, then this folder will be used to store the configuration instead (since Studio v2.8).
To use the --datadir option for switching configuration locations “on the fly,” one must use a terminal window and run the .app file via command line, as described in my docs.
I hope that helps!
-Max
PS. If you drag a new/different version of Studio into Applications, does it offer the choice of replacing the existing one vs. copying new one with a new name? If so, that might be the simplest solution.
Another potential option is to rename the existing “BambuStudio” in Applications folder, eg. with a version number or eg. adding “Stable” or “Beta”, before dragging/installing the other version(s).
However if all BambuStudio versions are in the same Applications folder, the trick with “configuration” folder will not work as intended (since all versions since 2.8 will use the same “configuration” folder).
