How/where: Start Laser/Cut processes from USB drive
Hi Bambu Suite users
The process to send 3d-print files to the printer from bambu studio is straightforward. The cutting/plotting process, on the other hand, is more complicated. I currently have to switch back and forth between printer and computer several times (computer: design/prepare project → printer: switch on, calibrate for cutting → computer: send project from PC → printer: place vinyl foils/paper on plate, start job with button). As my computer is not on the same floor, this is not very convenient.
But there is a solution: According to the new firmware (see H2D firmware release history | Bambu Lab Wiki) it should be possible to send projects from Bambu Suite to the USB memory and execute them from there. I was pleased about this update.
Unfortunately, I did not find this function in Bambu Suite. How exactly can I send the project file to the usb drive of the printer without directly starting the cutting/plotting process? Or have I misunderstood this?
Thank you for your explanations and tips
  1. Click the Bambu sign on the top left corner.
  2. File
  3. Export
  4. Export .gcode.lac to your USB flash drive
