Humidity Sensor?
Hi.
The description of the AMS mentions a humidity sensor. How can I retrieve it? Is it even possible ?
Great`s from Germany
there is a sensor build in , but at current moment the slicer/firmware does not use it to report any data
it is possible to get the data from it with a “hack” ( just reading some data points ,not really a hack )
but for now, there is no official way to read it
it will come avaible in the future at some point.
Hello,
Thanks for the answer. I already thought something like that. There are still a few sensors that are currently not really doing anything. The sensor on the door for example? Does it already have a function? Or the installation space temperature? You can’t really set them. In other words, active heating doesn’t work, but for example only after that temperature x switch on the external fan… I think there are still a lot of things that aren’t really integrated. But will come. I’m quite sure. I know it no longer belongs in the AMS category.
Great`s Michael
The humidity sensor works after the last update.
I saw a warning yesterday, insufficient green bars displayed. How can you view the humidity value in the AMS. Can we have the humidity indicator added to the temperature screens.
Sorry, I see the small humidity indicator. Poor eye sight at my advanced age.
It would be nice if it could also display a percentage rather than just bars.
It used to be reported in the MQTT feed until it was removed in one of the firmware updates.
I would like the percentage displayed with numbers. An icon is meaningless.
That would be a great improvement!
Indeed, I’d like to read the actual humidity as well.
Anyway, I added an aquara humidity + temperature sensor.
My UI doesn’t look like this. It’s a water drop with a number 2 inside of it. Practically useless since it has no meaning. Somebody said that my desiccant needed replacement but I had just got the printer. My room is below 35% and a separate device inside the AMS shows 10% humidity and the desiccant is brand new and visibly orange. In short, I agree that the humidity percentage should be shown as well as the current actual temperature be shown
They may have chosen a humidity sensor with pretty terrible specs, maybe ±10% accuracy and worse down at lower levels. So the ballpark scale of 1 to 5 is meant to hide the readings.
I have a separate sensor in the AMS which measures 10%.
