I have completed around 320 hours with my P2S and AMS Pro 2 without any issues.
Until I tried Bambu Lab PLA Silk velvet eclipse (black and red) I have tried to use it on 3 occasions and every time it blocks the standard 0.4 print head after around 1-2 hours into the print?
The filament has been kept in a sealed container with silica gel in to humidity of around 20-25%
Normally I can get it unblocked, this time I’ve not managed which is really frustrating.
I heated the head and used the nozzle needle, but it seemed to be blocked at the top end where the filament goes in when I tried to remove it with pliers it just snapped off level with a top of the nozzle head.
I have tried using the cold filament through the top method to try to purge it but nothing seems to shift it, there is no way to clear the top part of the nozzle, I guess this doesn’t heat up as much as the tip.
Does this mean I need to buy a new nozzle? And how on earth does this one filament cause me so much problem when I can print literally hundreds of other things with standard and Matt PLA without any Issues??
Any help with what I could be doing wrong with the filament and ideas on if it’s possible to unblock a nozzle if the tip is clear but the blockage is at the top where the filament enters?
BTW can you buy nozzle cleaning needles? as I seem to have bent mine a bit trying to clean this one out.
The roll could be extruded unevenly so that it is to thick in some spots. If you have digital calipers, you can check the diameter in a few spots.
The other reason I can imagine is heat creep. It becomes dangerous if the temperature inside the printer rises above ~40°C. Then the filament starts to get soft above the hot zone and swells before the nozzle or in the upper cold section of the nozzle and blocks.
This should be solvable with the heated allen key method. I don’t know if BBL still promotes this. You first unmount the nozzle from the print head. Then you heat an 1,5mm allen key with ball end to at least 200°C e.g. with a lighter. Then you quickly press it into the rear end of the nozzle, so that it melts into the stuck filament. Let it cool down and then try to pull the allen key. Hopefully it will take the stuck filament with it. That method was in the wiki for the X1C, but they might have removed it due to people burning their fingers
1.5mm allen key, heat the tip of the nozzle with a lighter or torch, then push the filament through from the hotend inlet. Sometimes I add a little slug of extra filament to help force it through.
Try the hot hex key cold pull as described by @Alex_vG and @CarbonForge before dumping the nozzle. Heat creep is quite a common occurence which does not neccessarily ruin a nozzle. Be aware that you may need a bit of practice to get a feel for the procedure and that it may need to be done a few times in a row.
As for the next print with the Silk material, it is little bit more challenging than ordinary PLA. It is more prone to moisture uptake, warping and heat creep. So it is usually best to dry the filament before using it again.
Yes, absolutely. Filament Drying Recommendations | Bambu Lab Wiki
But you want to be on the look out for a cheap dryer during black week or second hand. It makes life much easier when you can just dry some filament while the printer is busy.
I’ve also done the same trick with a straight pin (like for sewing), it penetrates into the filament well when heated. I did have to do the extraction with pliers since it’s harder to get a grip on the pin but it pulled out a piece almost the entire length of the hot end.
This is a classic symptom with silk and velvet filament, and I would not blame your drying. You kept it at 20-25% RH which is fine for PLA. Silk and velvet PLA carry extra additives that create the matte finish, and those additives slowly build up inside the hotend. After 1-2 hours of continuous printing the buildup starts choking the nozzle, which matches what you saw three times in a row.
For the current blockage: heat the nozzle to around 230 and do several cold pulls with cleaning filament instead of a needle. Push the cleaning filament in, let it soften, then pull it out while the heat is on. Repeat 3-4 times. If that does not shift it, just replace the nozzle. The 0.4 hotend for the P2S is cheap and it is the fastest fix.
Going forward, lower the print speed for velvet filament and pause between long prints to do a quick purge. Also grab the official nozzle cleaning needle kit from Bambu, it comes with a proper set and the needle is less likely to bend.
