Printer: A1
Timelapse: Enabled
When i try to view my timelapses from Bambu Studio, it just says ‘File does not exist’
Also, I can’t seem to disable the timelapse feature no matter what i try.
Please help
, and thanks in advance!
- Adrian
I timelaps sono sempre attivi, dai parametri dello slicer. Lo puoi abilitare o meno nel momento che invii la stampa, in quel momento ti appare una finestra e li puoi decidere se attivarlo o no.
Una volta finita la stampa ti dovresti trovare il timelaps fatto, se non lo trovi ci sono due motivi o non lo hai fatto partire, perchè di defoult, nella finestra che ti appare quando invii la stampa non è attivo. Se invece lo hai attivato prova a togliere la schedina sd e verificare al suo interno se c’è
When you say “enabled” do you mean within the slicer or when you select “print” and the pop up appears before it’s sent? The slicer only allows you to pick which you’d like (traditional or smooth), the pop up determines if a timelapse will be done, or not.
If you have been selecting timelapse on the pop up then you may want to check the memory card you’re using. It may have issues and is not able to actually save the file.
Thanks for your response!
I will try that.
By ‘enabled’ i mean the timelapse option has been turned on in the bambu studio print dialogue
Translation:
Timelapses are always active, by the slicer parameters. You can enable it or not when you send the print, at that moment a window appears and you can decide whether to activate it or not.
Once the print is finished you should find the timelapse done, if you can’t find it there are two reasons either you didn’t start it, because by default it is not active in the window that appears when you send the print. If you have activated it, try removing the SD card and checking if it is there inside
