I can't remove the nozzle
Mine is stuck and can’t remove it. I heated up the nozzle manually to 200C but it will not come out of the holder.
Have you tried using plyers?
Did you cut the filament off
Did all that and found a couple of YouTube videos on stuck nozzles. Manually heated up the nozzle to 250, let it cook for a few minutes and then gently put a small screwdriver behind the nozzle and it pried out. No idea why it was stuck so tight but I guess it’s a common problem. Thanks for the reply.
Just my 2 cents: The nozzle itself is clamped on the front. Did you unclamp it?
Yes I did. Evidently this is not an luncommon occurrence. YouTube has a couple of videos on this subject.
