I am working on a part to use as a cover for my window fan when the fan is turned off to prevent the hot or cold air from outside entering the room.
This is the fan. I 3D printed a bracket that attaches to the fan and fits into the part of the frame on the right. I glued a couple of rubber strips onto the bracket to seal it with the window frame. I have another 3D bracket on the left to hook it onto the sliding window on the left side. I also printed a box shaped model to seal the top with some insulation inside the box. The top model fits into the right side window frame the same way as the fan bracket.
I also 3D printed the cable clip on the bottom right of the fan, it hooks onto the rivets on the fan frame. This is what the clip looks like:
This is what the brackets look like to hold the fan into the window. The grey part is to simulate the fan for sizing and positioning of the brackets.
This is the right bracket. It is made of two parts on the left that are joined together and attached to the fan. And one part on the right that fits into the window frame. The red parts are the mods for the screw holes, which are printed as solid plastic using 100% rectilinear. When designing it in Fusion, the mods are sub-components of the part.
This is a picture of a test piece that I was using to make the right bracket fit tightly in the window frame. To reference it with the drawing above, it is a picture from the bottom. The black on the bottom edges of the part are the rubber strips I glued to the part to make a good seal. The rubber is on the front part of the bracket. In the drawing above, the left faces are the front.
This is the left bracket. It is made of two parts on the right (of the left picture) that are joined together and attached to the fan. And two parts on the left that are joined together and hook onto the sliding window on the left side. In addition to the screw hole mods, I made some internal rib mods that are embedded within the infill. The ribs are lined up with the screw hole mods and are used to prevent the part that hooks onto the window from breaking at the corner. The image on the right shows what the internal ribs look like. When printing I made the rib mods 100% rectilinear, the rest of the infill was gyroid.
This is what the fan cover will look like, it will be white. I cut it up into four sections for printing, and the circular part missing in the center will be another 3D printed part.
The holes on the right side (holes will also be repeated on the left) will be used to screw on an attachment that will hook onto the metal frame of the fan to hold the cover in place and also have a handle going the other direction to use to hold onto the cover. I made the part that hooks onto the fan frame an attachment so it can be modified and replaced without reprinting the fan cover pieces.
This is what one of the four sections look like, the yellow parts are the mods.
The rib structure on the inside corner wasn’t put there for support, I added it so I could make the corner a 45° angle so it could be printed without supports or defects like the picture below:
The fan cover is meant to insulate, so I am using 7% cubic infill because it makes pockets of air in the model which is good for insulation. Since this infill wouldn’t be good for supporting the screw holes, I added some modifiers to strengthen that section.
The part is supposed to be printed in the orientation in the slicer image above, but I put it on its side for the picture below so the infill differences are more visible.
I made two mods a few millimeters larger than the holes for the screws and nuts, and made them 100% rectilinear infill so it would be solid plastic. I then used another mod to surround the screw holes and made it 20% gyroid to hold the screw/nut mods in place. I extended the mod surrounding the screws to the bottom of the part at an angle so that it supported itself while printing.
I made the mods sub-components of the fan cover in Fusion. This is what the screw/nut hole mod looks like:
This is what the screw surrounding support mod looks like. I used Fusion’s combine tool to cut the screw/nut mod out of the screw surrounding support mod so the mods don’t overlap.
