I need help constantly having issues
I would suspect a clogged nozzle or ,less likely, a clogged extruder. Have you tried a cold pull?
Yeah I’ve tried that, the nozzles have been removed inspected, cleaned cold pulled. I’m now convinced that it’s printer issue as I’ve tried 4 different brands of filament my go to was Overture changed to Sunlu then Elegoo and also Bambu and all in Matt what I consider standard pla. They’ve been dried I’ve tried part used rolls that printed perfectly fine a few weeks ago.
Try to set temperature 5-10 degrees higher, it looks like it’s not melting enough.
