I need your help! I want to make something for the new contest, but I’m not sure if it might somehow go against the rules, or if someone might think it’s copied or made by AI, or if it already exists somewhere—I don’t even know. So before I even print it, I wanted to ask here: what do you think???
hello,
you can use this photo as a proof it isn’t an AI generated.
also if you done this design by yourself out of your imagination I’m pretty sure it wont be a copy or similar to other designs…copied designs usually be the exact same or something with a very slight difference.
nothing to worry about and wishing you best of luck in the contest.
Edit: don’t forget to test print it before you post the model and don’t forget to post real photos of the printed object (print profile photo and the display photo).
Once you print it out, it won’t look like the image that you show. The photo that you take will show the imperfections of 3D printing.
The judgement will be made by MW, not people on this forum. If what you show is your own creation and not some model imported into your CAD, then you should not have to worry. You will have the multiple iterations in your CAD to prove it if it’s challenged.
