Idex printer
hy guys, anyone knows if its possible to add a two extruder printer like sovol sv04 idex on bambu studio?
thanks
Not in Bambu Studio, but I do see a two-extruder Ratrig model in OrcaSlicer, so I assume you could work with that.
thanks… i ll try on orcaslicer first…
I tried it with my toolchanger. Unfortunately, it is only possible to define one print head.
BUT: When I create a print job with two materials, a tool change actually works. The only problem is that the second print head remains cold. I think the problem could be solved by adding a heating command to the start script. Unfortunately, the temperature would then be independent of the selected material. And there would also not be the option of selecting a standby temperature, which would not be possible with larger materials.
