Impossible to import Esun profile
Hi there, I have a problem importing the profiles from the esun website
I have downloaded the profiles of all esun filaments for my P1S from this website
Esun filament settings
After unziped the file I choose from the list the LW-PLA files, then from Orca slicer I imported both the configurations, but I can’t find them either into the filament setting and also in the printing settings.
I also copied the files into the orca’s folder
C:\Users\Dorimax\AppData\Roaming\OrcaSlicer\user\2768867204
Any idea ?
did you add them within Orcas settings? Like the ones from Bambu and Ovature?
Hi, yes I did it.
I have several profile for esun like PLA+ and ABS never a single problem
For me, I had to use a different printer. Somehow the P1S profile works for my X1C. I think there are some problems, but I just imported the TPE one and with this it worked all fine.
Maybe that is also the problem for you.
Hmm, ich verfolge einen anderen Weg…
Unter Datei → Importieren → Konfigurationen importieren importiere ich die filament datei und / oder die Prozess Dateien.
Danach findest Du die Importierten Filamentdaten im Filament Auswahl Pulldown Menu, respektive Prozessmenu.
273 / 5.000
Hmm, I’m taking a different approach…
Under *File → Import → Import configurations ) I import the filament file and/or the process file.
You will then find the imported filament data in the filament selection pulldown menu or process menu.
*) I use the german Version of Bambu Studio and don’t know the exact english Notation
Vielen danke, but I already tried to import both profiles in that way and is not functioning
Hi
It didn’t work ?
Do you extracted all files from the ZIP Container
for Example the File P1S eSUN PLA-HS Filament.json
(by the way, you can edit with a text editor the json file and rename the name you will see after the import)
Then use the Import Function.
I have done it multiple times and it works
Hi, I have found another .rar from Esun and that was functioning
