Improve setting print order
Dragging and dropping in the process window is glitchy, annoying, and sometimes can’t be done. I will drag a part to the top of the list and it gets put 2 down, or other parts under it get mixed up. Sometimes I have a lot of modifier shapes on a part and I can’t see the top object to be able to drag the bottom object above it.
Improvements I’m hoping for:
  • Directly type the sequence number into the info box that hovers over the part in the main window that shows their sequence number on the build plate (ctrl-shift-e).
  • Add an editable sequence column in the Object/Part Settings window (Parameter Table)
  • Let us vertically resize the Process tab on the left toolbar so that we can see more parts at once.
