Is their a way to increase the flow rate and keep it standard when using rafts?
I noticed the flow seems to drop off massively which ruins the finish on the base of your parts…
I have attached a photo showing the difference between Creality slicer and Bambu Studio, with Creality slicer the flow remains the same and at a 0.2 layer distance the raft peels off like selotape and the finish is nice however with Bambu you can see the flow changes as it treat the rafts first layer as the ‘initial layer’ and the finish is terrible, leaving gaps and a rough texture
I have also noticed the initail layer speed only applies to the raft and not the first layer of your model so its not possible to slow the wall speed down on the base of your print - The following photo the initial speed was set to 35mm/s which it is only applying to the rafts first layer…
