hello, i get a hard line here, how to make it smooth?
Hi @Jovianwirja
Are you referring to the layer near the Polgar?
Please provide more information, such as nozzle diameter, and print settings (e.g. using default profile X with these changes: Y, Z, …)
Also, are the filaments calibrated, especially flow rate and pressure advance? Dry?
If want to simplify, share the .3mf file.
It isn’t obvious what you mean.
Do you mean the colour bleeding from the black parts into the white parts?
If so, two things can improve it.
- Most likely: Change the filament sequence of the first and subsequent layers, so white is printed before black in any layers.
- Increase the flushing between the white and black transition.
Do you mean the overhang line that appears in the left of the photo near your hand that goes to the bottom of the white face portion?
If so, this is likely part of the model design and is simply a tough angle.
Filament sequence
- Use the hex/cog icon next to the build plate in the preview tab.
- Change the first layer sequence and drag the white swatch so it appears before the black one.
- Consider ordering so the lightest colour is first moving towards the darkest colour on the right.
- Repeat this for the following option for the subsequent layers.
Flushing
- In the prepare tab, select the flushing button (near the filament pool)
- Locate the intersection between the white and black filaments.
- Increase the number
- This is all about experimentation
- The larger the number, the greater the waste material
I have cooked it better with variable height but there are lines appearing in other places how do I get rid of lines like this?
ini file saya ![]()
Head blue cat terbaru.3mf (654,2 KB)
Hi, I get a solid line here. Is this line from layertime? How do I set it so my object can be smooth?
hello there, this forum section is dedicated to makerworld (the platform) topics only.
you can post your concern at bambu lab software section Here you will get an effective and faster response there.
i hope you get it resolved soon, best of luck.
hi i have a solid line here and i see it quite clearly in layertime and the print result. is there any solution to smooth it? i have used variable height but it still has a solid line. and i also get melting from the black filament is there any solution for that too?
Head blue cat settingan terbaru.3mf (1,2 MB)
thank you so much for your respon
