Hi, noob user here, starting to have this print issue as shown in the picture . Any idea what’s causing it. Tried different filaments with same result.
That is under extrusion. Either the nozzle is partially clogged or your filament calibration is off.
Have you done any of the manual filament calibrations from the “Calibration” tab in Bambu Studio?
For a clog you can perform a cold pull to hopefully pull whatever is in there out. Also you could try a different nozzle and if it fixes the issue you know it was a blockage.
