Currently a print starts by printing a line along the back of the build plate and wrapping wrounf the right hand side. Then a second line is printed along the front edge. These lines reduce the build area unnecessarily. For example, there is no 256mm axis available (except diagonal).
Request: please print these lines along the front edge of the build plate (where the cutter mechanism already reduces the available area). This will provide a 256mm long X axis.
(The front area is already used by the flow calibration, but I believe there’s enough space there to fit everything.)
It has an effect on build volume in that it prevents me from getting a clean print where the purge lines are. Especially for thin parts or if there is a bridge or overhang in that area it is not something one can just ignore.
