Increase the limit of k-factor profile name from 40 characters
Can we increase this limit a bit so I can fit both brand, type and color? There are a couple mixes where these all don’t fit. Especially if you want it too look a bit organized for example: “0.4mm - Polymaker, Polyterra PLA - Savannah Yellow”
Also please add some way to organize these, renaming, modifying and please sort them alphabetically and not by creation date.
Ditto the above.
If it allows a filament profile to have above 40 characters then it should allow the flow ratio calibration results to use the same name.
We should not have to make an additional profile with a far far shorter name esp give that we cannot remove the one above it.
By the way, as a workaround if you do the 2nd profile with a shorter name, you can edit that, copy the flow value and add that to the original profile.
Then delete the 2nd shorter named profile.
This is currently logged as a bug:
