Infill color
So I know previously it was possible to add a modifier shape or add a shape inside the model to change colors inside the model itself but it looks like that ability has been removed with one of the updates.
Basically I am trying to print yellow or white letters cut into (negative) the model (so if the model is 10 layers thick, they are insert like 5 layers (numbers are completely made up just using them as an example) on black and it’s not working well. I thought I’d just change the infill colors under the letters but as mentioned above, the ways I could think of and found others has done previously, no longer work.
Any ideas?
