Initial prime/purge test pattern
Is there a way to re-position and/or shrink/disable the initial prime/purge pattern that is done prior to print on right side of print plate? It is overlapping with my print and can’t find a way to move it.
There is no setting for this as far as I know.
If you’re printing the same filament I would just disable the flow calibration for this certain print. It then only prints one purge line in the front and the two lines in the right back corner. The printer will use the flow values from the last calibration which should be working fine.
You can add a pause on the first layer of your model (in the sliced view, right click on the layer on the left hand bar) - this will allow you to remove all of the purge and calibration lines on the bed before your model starts printing.
