Inland PETG+ print issues
Hi everyone,
I’m hoping I can get some help here. I’m trying to branch into petg and started with petg+ (Inland Brand from Microcenter). I’m getting some issues with blobbing and stringing. I’m using the Generic PETG+ setting on a P1S. I have thoroughly dried my filament and am printing from the dryer while it’s running (sunlu ams heater top).
I’ve been printing for a few years but just now got the courage to try to use a more advanced filament. I’ve been drying my filament for well over a day and still getting lots of issues. I’m also using the 0.2 bambu standard default setting. I get really nice clean first layer adhesion and as the print continues the blobs and stings eventually start. It’s a bit frustrating but all part of the learning. Any advice I can get would be awesome. Really appreciate you all.
The initial issues that I had were adhesion of the 1st layer and some stringing. I started using a Glue Stick and I bumped up the Bed Temp to 75C/78C for the first layer and then 73C for all of the other layers and I have had pretty good success. 3D printing since May 2026.
I just thought of something else that you could try and that is to print a Temperature Tree test print. That will show you at what temp your setup for your physical location works best for your printer.
I think this is a good idea as well. Is there a way to do this in bambu studio or would this need to be done in Orca?
Tried another print and got a lot of issues with it too.
Just search for “temperature tower” in MakerWorld. It’s just a 3mf print job.
Also go on YouTube and search for temperature tower and watch some videos before printing one.
https://makerworld.com/en/models/101483-petg-temperature-tower-temp-tower-g-code?from=search#profileId-1269620
I keep finding better print jobs. This one would be better for stringing issues.
https://makerworld.com/en/models/512668-bambu-petg-temperature-tower-240-270-degc?from=search#profileId-428764
I believe I use the eSun profiles for the inland filaments. If I remember correctly, inland is made by Polymaker or eSun, and I’ve used PLA, PETG and ABS from inland using eSun profiles with no issues, after drying the filament well.
Hey so I checked my bambu lab profiles and don’t see any PETG for Esun in the system. Did check and saw polylite petg profile for polymaker. I’ll try it as well. I did a temp tower test for both of my petg+ filaments and got similar results in the orange petg+ my 260 to 265 layers are good and 270 is usable. 255 lower is not and globs and strings. In my clear petg+ print 255-265 are the best and usable. 250 and lower is not. Neither tower I could let finish 245 and lower as it glob and would not adhere. These were using the Generic PETG profile in bambu. Does anyone know why these would be so much higher than the printer spool temp and the normal print range most people advise they print PETG with? Most are at 245-255 I believe?
Take a look here, see if it helps:
Also, how long have you dried the filament and at what temperature?
Have you tried inlands website / forum / support ?
Been drying for hours. Like well over 10-12 as I predried and then I print while drying as well. 55-60C for the dryer. I haven’t tried the inland forums. Ill go check it out after work in a bit.
I’m really curious why the print prints so cleanly at such higher temps than the label.
Do me a favor. Attach a picture of the box and/or the spool.
Just so I know which filament you are talking about exactly.
Microcenter uses a few different suppliers.
It looks like you are not using a petg plus, but a petg translucent.
It is a translucent but it’s also labeled as PETG+. Attaching pics.
Yeah. Thats what I thought.
Translucent does not print the same as a normal petg plus.
Sounds good. Glad to now know. Again I’m new to PETG+ and PETG in general. Any tips or prior knowledge/experience you can share to help with success? Trying to learn and branch out into newer materials and filaments. Would this running hotter to print clean than what the spool label says be expected? Looking for helpful advice.
I was going to send you filament parameters, but I dont have one for translucent. Just the regular inland petg plus.
Treat it as a translucent petg instead of a regular one.
I would run a quick benchy with bambu petg translucent settings, see how that is, then go from there to set up a filament profile for it.
Slow is key.
I was going to post the wiki ,but the settings would be unsupported *generics both petg and pla translucent/clear
im guessing thats more about a glass clarity
Thanks guys this gives me a good place to start. Inland will be one of my main sources of filament due to how close Microcenter is for me. So I would happily take the profiles for the normal PETG filaments too. I really appreciate all the help. It means a lot. I’m excited to be branching out.
