Since the last firmware update, I have to remove and reinsert the SD card every time before I can start printing.
This issue occurred earlier in the year but had disappeared for a long time. Is there a workaround (aside from asking someone to do it locally) when the printer is powered on remotely, and I want to send a print job?
I had this problem for the first time yesterday too. I’ll take a look at the matter today.
If you also find a solution for this then let us know ![]()
I think the SD card is damaged.
I first wanted to keep the directory structure and only save all the data from the rIng memories. CAM logs etc. but that ran into a timeout.
At least formatting worked, but I had to classify the card at least as sus.
My card was also defective. I’ve now replaced it with a better 128 GB card and everything works again.
