Iron under text
How do i get Bambustudio to iron the whole surface under text? I have tried “Only 1 wall on top surface” and “Interface shells” but it still irons around where the text is which makes it quite messy during the print. It makes no sense to me why it does this.
Thanks in advance.
I’m not sure I understood your comment correctly, but let me give it a try:
Do you mean this feature, maybe, ironing? These are the options available:
  • No Ironing
  • Top surface
  • Topmost surface
  • All solid layer
This feature has nothing to do with ironing, in case you were wondering, but rather with:
With this option enabled, top surfaces will have only one wall, giving better appearance to top surfaces, especially for models with a flat top. This option is enabled by default. If you disable this option, the number of walls on top surfaces will be the same as the number of wall loops set in Strength > Walls.
When i slice instead of ironing the whole rectangle shape and then printing the text on top, it irons around the shape of the text and then prints text on top. Works ok with some filaments but not good with TPU.
I have “Top surfaces” in ironing selected.
Could you upload the 3MF to the forum, please? You can simply drag and drop it into the text field.
The text is not in the file. I add it to each print as it’s just the persons name
Just type in any name. Then save the 3mf file and upload it to the forum. This allows us to verify the settings you’ve made. :grin::+1:
Rear site.3mf (70.1 KB)
Thanks
I finally got around to checking out your 3mf: So here’s how things look right now: Ironing everywhere:
If you don’t want any ironing of the text:
  1. Switch from “Global” to “Object”
  2. Select your text
  3. Turn off “ironing” in the settings
Of course, it works the other way around, too:
Thanks,
I already did that. If you go down to layer 135 you will see that it still irons around where the text will go.
Then you’ll need to use a modifier cube and drag it over the area:
I interpret Jimmy6’s request as wanting to iron level 135 as if the text was not there, then add the text over the unbrokenly-ironed surface. I cannot do so. Tried stuff like 0 bottom layers for the text etc. It seems to me that the text would need to be a separate object, suspended in space to be “virtually” setting on top of Rear 2.0.stl and then they could be treated separately.
