Hi everyone,
I have a Bambu Lab X1 Carbon and I print with PLA.
For some time now, I’ve been experiencing an issue when ironing the top surface. Lines appear above and below obstacles, such as raised lettering, for example, while the ironing is perfectly smooth and uniform everywhere else (see photo).
Everything used to work perfectly, and I had never experienced this issue before.
I’ve run several ironing tests to fine-tune my settings, but nothing seems to help.
Here’s everything I’ve already tried:
Updated Bambu Studio and the printer firmware.
Replaced the nozzle.
Performed a full printer calibration.
Recalibrated the filament flow rate.
Tested and adjusted the ironing settings.
Performed printer maintenance.
Tested two different PLA filaments.
Dried the filament.
Despite all these attempts, the issue persists, and I can no longer achieve the same clean results as before.
If anyone has experienced the same issue and found a solution, or has any suggestions, I would really appreciate your help!
I’m starting to get desperate because I honestly don’t know what else to try.
Thank you very much in advance for your help and your time. ![]()
