Ironing with my A1
I just having a bit of trouble using the ironing option on my A1. I also have an X1C that does the ironing process quite well.
This is the original problem. Filament is PETG-HF…
I thought it might be the filament so I made a test piece and printed it in PLA…
Adjusting the ironing flow rate from 10% to 20% made it worse…
For now, I’ve reverted to no ironing and this is the test piece printed in PETG-HF at 0.20mm.
Like I said the X1C irons great with PLA and PETG, it’s something with the A1.
i have the same problem with my A1 with pla , after last update
Were you able to workaround? Or just set the A1 to No Ironing?
i set the flow at 25% , It has improved slightly
after the last software update my iron on my A1 is goon to heck too. i use the my sign site and i just waist print after print trying to fix it and its garbage. Please Bambu fix this its not on our end I’m sure of it.
EDIT:
ok so i went back to Bambu Studio v01.10.02.64 and the ironing was perfect. no more rough or wavy top surface. what ever is broken in the v2.xx.xx.xx version i hope they figure it out soon and fix it.
I actually made a model to find a good ironing setting on my A1
For me, 10mm/s and 14% flow works best. But i havent tried it in Bambu Slicer v2, maybe the problem is in the newer versions.
