Is it Possible to Disable Gap Infill?
Im having an issue with an with slicing a file with articulated parts. The gap infill is filling a hole and it is messing with the print.
I set closing radius to 0.001 and contour comp to -0.05 but can seem to get rid of the gap infill
CleanShot 2023-04-08 at 17.05.51
Is there a way to disable this?
It will be disable if you use Archne (adptative layer wall width) for Wall generator under “Quality” tab
You can change the “wall generator” from classic to Arachne.
That might solve your problem
I had a similar issue and your comment fixed it. Thank you.
love u su much, it worked
you can also set the gab infill speed (process → speed → other layer speeds → gab infill ) to 0
Setting gap infill to 0 doesn’t get rid of it for me
